y2k1234njmh
Jul 05, 2026Aspirant
V7.2.8.5_5.1.21 RBR850 memory leak
I keep tracking RBR850 memory usages via its debug page. I saw it increased 1MB per day. After rebooting it took about 350MB and after online about 10days it reached 450MB so I need to reboot it every month. I hope it can get better in next firmware release.
- y2k1234njmhAspirant
V7.2.8.8_5.1.24 seems fixed the issues. So far it holds 350MB for days.
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
I did one factory reset it doesn't make difference. I just reboot it when it took more than 600 MB. I did not turn log on but I do have lot IoT devices. I have almost 200 devices on the network. After reboot it allows took about 35%cpu and 350MBs
What happens when it reaches 450MB or past this? Does the system fail?
I did not notice major perform problem yet but I reboot it anyway. I don't feel comfortable bufferbloat latency
I just reboot it when it took more than 600MB. It seems consistent.
Has a factory reset and setup from scratch been performed since you applied this FW update?
What all is connected to the router?
What features are enabled on the RBR?
Is any logging enabled on the RBR? Debug or Admin logs?
Yes. I did factory reset once. I do have about 20 LAN reserved IPs and IoT set 2.4G only debug off and one FTP forwarding all others are defaults. I did not notice performance degrading since I reset when it grows up to 600MB.
What happens when it reaches 600MB or past this? Does the system fail?
