CT4511
May 14, 2025Aspirant
WAN port of my RBR850 has been stuck at 100m
I am having the same issue where WAN port of my RBR850 has been stuck at 100m. All other LAN ports are at 1000m. I tried using CAT6 and 6e both, brand new cables, but no luck. The WAN port pins ...
CT4511
FW - v7.2.6.31
Modem is provided by NBN company in Australia so not NG but I tried it with other router and it gives 1000m so not a modem issue I am assuming.
Based on earlier solution in this thread I had tried connecting my laptop to RBR using USB-C to Ethernet port connector from laptop to WAN port of RBR. I don't think it was useful as probably it didn't have 1000mbps link/connection itself (due to USB-C may be).
I will take RBR to my workplace and test as you have mentioned to see if it changes to 1000m. Will post the update. Thank you.
