CT4511
May 14, 2025Aspirant
WAN port of my RBR850 has been stuck at 100m
I am having the same issue where WAN port of my RBR850 has been stuck at 100m. All other LAN ports are at 1000m. I tried using CAT6 and 6e both, brand new cables, but no luck. The WAN port pins ...
CT4511
FW - v7.2.6.31
Modem is provided by NBN company in Australia so not NG but I tried it with other router and it gives 1000m so not a modem issue I am assuming.
Based on earlier solution in this thread I had tried connecting my laptop to RBR using USB-C to Ethernet port connector from laptop to WAN port of RBR. I don't think it was useful as probably it didn't have 1000mbps link/connection itself (due to USB-C may be).
I will take RBR to my workplace and test as you have mentioned to see if it changes to 1000m. Will post the update. Thank you.
May 14, 2025Guru - Experienced User
Most USB C to ETH adapters these days are 1000Mpbs supporting.
Let us know what it shows at your work place. Can connect any PC or even a LAN switch up long enough to see WAN port speed while another PC is connected to LAN port and it's web page.
Helps for us to know model of the ISP modem/ONT as reference.
