2JA
May 31, 2021Follower
want to connect satellites by wire (wifi connection not possible)
RBK753 — Système Orbi WiFi 6 AX4200
Hello,
Got in replacement of my RBK50 the RBK 753 Wifi6.
My old system was wired and everything was fine.
While replacing the system, I wanted yo connect the sattelites by cable but it doesn't work.
The sattelites want to connect by Wifi on the main Orbi router, wich isn't possible.
i tried everything and can't find the solution
What should I do.
Thank's in advance
You have posted your message in the section of this community given over to General WiFi Routers (Non-Nighthawk). (This is easily done, given Netgear's complicated community structure.)
Many questions apply to different types of device, so you might get responses here, but you might get more help, and find earlier questions and answers specific to your hardware, in the appropriate section for your device. That's probably here:
Orbi - NETGEAR Communities
I will ask the Netgear moderator to move your message.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
You may have done this already. I can't tell from your message.
I mention it because Netgear gave up on supplying paper manuals years ago and people sometimes miss the downloads. - FURRYe38Guru - Experienced User
Is the Orbi system operating in Router or AP mode?
What is the Mfr and model# of the ethernet switch in the configuration?
https://kb.netgear.com/000051205/What-is-Ethernet-backhaul-and-how-do-I-set-it-up-on-my-Orbi-WiFi-System
2JA wrote:RBK753 — Système Orbi WiFi 6 AX4200
Hello,
What should I do.
Thank's in advance
