Phyber
Dec 22, 2025Apprentice
What are the recommended Channels and Channel widths for an RBR750 system?
Thinking about tweaking my system but it's been a long time since I've done that so what are the recommendations for 2.4GHz and 5GHz channels and channel widths. Simple home system, nothing elaborate...
Phyber
Thanks gentlemen. I do not have a WiFi analyzer on my iPhone and I'm not sure how to use one if I did. For 2.4GHz I have it set to Auto. For 5GHz, I believe it's set to 48, which is 36 + 40 + 44 +48(P).
I use the Guest Network (re-named to something else with its own pw) for my IoT devices. Most of which are 2.4GHz only but some use the 5GHz band. I do not use the named IoT network at all.
Dec 23, 2025Guru - Experienced User
Phyber wrote:For 2.4GHz I have it set to Auto. For 5GHz, I believe it's set to 48, which is 36 + 40 + 44 +48(P).
Both of these are reasonable.
Are you seeing any wifi performance issues?
- PhyberDec 23, 2025Apprentice
Not really. Just looking to see if I can squeeze a little more performance out of my system. I just updated to the latest firmware for the 750 yesterday. That went well and appears to be stable, so I like to check with those who know than I do about networking to see if there is a better config setup.
- FURRYe38Dec 23, 2025Guru - Experienced User
Go with whats works best for you, the system and your envrionment. Not all envrionments are the same so will be some differences.
Use what works best.
Also limiting the features being enabled on the system can have some impact. Armor, SPC and Guest Network Or Traffic Meter, I don't use so those don't impact anything for me.
- StephenBDec 23, 2025Guru - Experienced User
If you want to try some experiments, you could try
- channel 149 for 5 ghz
- channels 1, 6, and 11 for 2.4 ghz
If it doesn't make much difference, then I'd revert back to your existing settings.
Note the environment can change - depending on exactly what your neighbors are doing, and also you can get interference from other sources (bluetooth, microwaves, other stuff). Plus speed tests are going over your internet connection, and mileage there also varies.
So if one of your tests is giving "good enough" performance, then keep it running for a day or so, and periodically check the performance. When you do that, run a couple tests in a row.
- FURRYe38Dec 25, 2025Guru - Experienced User
Channel 149 can't be set on Orbi AX systems. Only channels selectable is 36 thru 48.
The higher channels are used by the BH system.
