mophilly
Nov 29, 2021Aspirant
What does the RBRE960 "Enable IoT" option do?
I have a number of small service devices, like a doorbell, outdoor lighting controllers, and so on, that are connected to my home network. I have an AXE11000 WiFi Mesh System (RBRE960) installed and ...
mophilly
FURRYe38 wrote:Netgear has set up a community forum specifically for the Orbi AX (WiFi 6) products. Most of the people who watch that forum are more likely to have experience with Orbi AX and know how to work it better than those of us who follow this "general Orbi" forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
Helps you setup 2.4Ghz only IoT devices to the Orbi system.
Thank you
Thanks. I will post there in the future.
Nov 29, 2021Guru - Experienced User
Moderators moved your post so your in the right forum.
Good Luck.
