Dbsoccer
May 24, 2025Aspirant
What is a IoT device and how do I determine if I have any
I have the same question as Psychopasta had nearly three years ago so I'll just tag on the end this discussion. When I just recently re-created my networks following a 'train wreck' of sorts I n...
- May 26, 2025
Thanks TC_in_Montana. You've provided a lot of things to look at and learn about. I think I may now know what this mystery MAC is and will be able to confirm later this week. At the end of the day it really doesn't matter but I like to have things tidy. I may have too much coverage so I'll look at your suggestions. We have a two story house with a basement. I have the router on the top floor in the office. One Sat is on the main floor and one is in the basement. There is a Peloton in the basement on WIFI and it is a likely place for people to be on their cell phones while watching TV. The TV is hardwired as are the Satellites.
This all started with resetting my router to FS. During the reconfiguration I selected the radio button to "Use The Default" for the Router MAC address. As I'm learning more it seems like my Router has a fixed MAC address so why not use that instead of a Default or, the other option, The Computer MAC address? It may not matter as it seems to work fine. But instead of using DNS addresses from the ISP I'm using something another contributor suggested that being a fixed address.
Again, everything is working as I hoped but there may be improvements I can make and I find this interesting.
Retired_Member
May 24, 2025Google results are sometimes incomplete.... (or misleading). TC_in_Montana was "spot on" that when customers complained that many of their gizmos could not be connected to their Orbi systems (because the smartphone app was poorly written), Netgear refused to provide a method to temporarily turn off the 5G radio. Sure, everything in the house that was connected at 5G would temporarily be out of service. Instead, Netgear created this "IoT Network" which DOES allow the customer to turn the 5G radio off and on at will.
If every device you want to use connects to the network, there is totally no need to enable the IoT network.
