Jazz_LFC
Feb 12, 2026Follower
What is Compatible?
I have a NETGEAR - ORBI AX4200 MESH WIFI6 2 PACK. I need to get an add on however this current model is no longer available. What can I get that is compatible?
Feb 12, 2026Guru - Experienced User
There's a guide that tells you what is compatible. If you can't find any in stock, renewed or used systems can be bought and the satellites paired with your old system.
https://kb.netgear.com/000065169/Which-Orbi-routers-and-satellites-are-compatible
