ElDje
Jan 07, 2024Aspirant
When trying to "apply" changes, get a "400 Bad Request"
Hi,
I have the same issue...
Firmware up to date (V7.2.6.21_5.0.20)
When selecting, then deselecting the "Support Automatic Pri...
CrimpOn
Jan 07, 2024Guru - Experienced User
ElDje wrote:
When selecting, then deselecting the "Support Automatic Private IP Addressing (APIPA)" , then "Apply" works...
Could you please humor an Old Guy and make a screen shot of the Help information that pops up from the bottom of the screen when the arrow is selected? I understand what APIPA is, but am totally confused about the meaning of "Support..."
These automatic IP addresses are in a totally different IP subnet from the normal private IP address spaces:
I have two different Orbi routers, and neither has this option on the LAN Setup page. Nor can I find any mention of this option in the RBR850 User Manual. Sort of hoping that there is information in the Help screen that may explain what this option accomplishes.
There was a post on the forum back in 2022 asking about this, but no answer.
https://community.netgear.com/t5/Orbi-WIFI-6-AX-AND-Wi-Fi-6E-AXE/APIPA/td-p/2257586
There is a Knowledge Base article saying that firmware v4.6.9.11 adds support for APIPA:
https://kb.netgear.com/000065128/RBR840-RBS840-Firmware-Version-4-6-9-11
Thanks
p.s. If this is obvious and I am just "dumber than dirt", somebody please point me in the right direction.
APIPA was a unknown feature that came in on v.11 back then. We asked NG was that was about but i don't honestly remember the feedback as as to why they put it in, it's been too long. This feature should not be in current v7 FW as NG removed it.
The user should factory reset the RBR and setup from scratch. Be sure to clear out all browser caches as well before starting the setup routine using a web browser and PC.
The user should be able to use any of the 3 IP class referenced as they are mentioned for home IP configurations.
