Ambyers14's avatar
Ambyers14
Whitelist servers?
I recently purchased some exercise equipment that connects through their app to their servers with exercise videos. As part of a troubleshooting process with their support team regarding video quality, they ran a performance test on my network using an Orbi RBR750 mesh. Their diagnosis was that I had a firewall in place that was limiting the connectivity to their servers.
Their recommendation was to whitelist their servers, and they sent me a list of several servers and several specfic TCP and UDP ports.
Can anyone point me in the right direction as to how to accomplish this? From what I can tell, the Orbi app only allows me to unblock specific URLs.
  • > [...] they ran a performance test on my network using an Orbi RBR750
    > mesh. [...]
       I don't know what that means.  Who was "using an Orbi RBR750"?
    > [...] Their diagnosis was that I had a firewall in place that was
       I don't know what that means.  Or how they reached that "diagnosis".
    > Their recommendation was to whitelist their servers, [...]
       Hard to do when there's no blacklist to overcome.
    > [...] they sent me a list [...]
       With my weak psychic powers, I can't see it from here.
    > this?
       Not I.  None of it makes any sense to me.
    > Model: RBR50|Orbi AC3000 Tri-band WiFi Router
       Firmware version?  Connected to what?  Do you also have an RBR750?
    With what equipment, exactly, are we dealing?
    • Ambyers14's avatar
      Ambyers14
      My equipment is a RBR750, not an RBR50. The 750 option wasn't available for selection. Sorry for the confusion.
      I don't know how else to clarify the situation for you, as that was the information that I was given.
      • antinode's avatar
        antinode
        Guru
        > My equipment is a RBR750, [...]
           Ok.
        >   Firmware version?  Connected to what? [...]
           Still wondering.  Have you some kind of modem, for example?
           Still true.
        > [...] that was the information that I was given.
           There's still nothing in it with which I can work.  If they tell you
        to climb down from your rooftop, but you're not on your rooftop, then
        that advice is worth how much, would you say?
           Still true.
  • While I do not have an RBR750, I did just glance at your user manual, and it says you can indeed block/allow ports in the router menu here: ADVANCED > Security > Block Services
