Aerfally's avatar
Aerfally
Why Does Orbi RBK853 Have "No connected device found" after latest update
Bought the RBK853 system (RBR850 + 2 associated satellites). Paid $999 for it. You'd think it would work super well. No. Since the latest update, internet works but neither the Orbi app nor the web-based browser management tool can see individual connected devices. The satellites show up, the total device count shows up (78), but the individual devices do not.
Here is the kicker - the individual devices show up for the first 1-2 days after restarting and/or resetting the system (I've done this 4 times now), then they disappear. The satellites have wired backhaul but the same issue arises if I run them wirelessly.
Netgear, Orbi, what the actual f? Starting to get really tired of this.
  • FURRYe38's avatar
    How was the system updated? Thru Orbi app or using the RBS and RBR web pages?
    What browser are you using?
    Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
    https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
    What is the Mfr and model# of the ethernet switch in the configuration when ethernet connected?
    I haven't seen this with my 8 series on newest version of FW.
    • Aerfally's avatar
      Aerfally
      Updated through Orbi App.
      Tried both Edge and Chrome. CNRTL-F5, etc. Cleared everything. Restarted.
      Also restarted the system multiple times. The connected devices show up for the first 1-2 days then disappear.
      Ethernet cables are rock solid. CAT6.
      3k sq ft home
      No ethernet switch
      Again, the system worked fine for 2 years. Now neither the app nor the browser tool work. It's inexcusable for a system that costs $1k to have these problems.
      • FURRYe38's avatar
        I would reload FW using MS Edge on the RBS web page then the RBRs web page using a wired PC. Orbi app has been known to not work right for FW updates. I personally never use Orib app for FW updates unless NG asks me to. After all is updated, power OFF the system for one minute then back ON.
        For that size of home, having two RBS deployed maybe too much. I have a 5000 sq ft home and most of the time use 1 RBS. If i have two deployed, the I reduce the power to 50%. Have see no issues like this with mine.
        For 3000 sq ft, if you need both deployed I would try 1 RBS or reduce the power to 25% if you really need two RBS deployed.
        Or revert back to the version of FW that was working for you.
