Elwood_85's avatar
Elwood_85
WiFi 6 icon is on my Samsung S21 BUT Orbi RBRE960 Attached Devices shows Connection Type as 5G
None of the other devices attached show 6G even though they are newer devices that are WiFi 6 capable.
The Orbi only shows 2.4G and 5G but no 6G . Should there be a 6G icon in Attached Devices Connection Type?
I am not running any Satellites just one Orbi RBRE960, residential single family home Firmware Version
V6.3.7.5_3.2.25
Your help is appreciated
Please see attachment
  • You're confusing wi-fi 6 (which is still 5Ghz) and wi-fi 6e (which uses 6Ghz and the separate radio in your RBRE960).  From https://www.tomsguide.com/face-off/wi-fi-6-vs-wi-fi-6e-whats-the-difference:
    1.  Wi-Fi 6 can send and receive data over both the 2.4- and 5-gigahertz (GHz) bands (Wi-Fi 5 is 5-GHz only) and can move even more data by running a single ultra-wide 160-megahertz (MHz) channel on its 5-GHz band.
    2. Wi-Fi 6e added more than a gigahertz of fresh electromagnetic spectrum space in the U.S., ranging from 5.925 GHz to 7.125 GHz... This additional block of spectrum, generally referred as the 6-GHz band
    The Android screenshot just indicates Wi-Fi 6, not 6e.  From https://www.androidauthority.com/wi-fi-6-910014/ : If you see a number 6 alongside the Wi-Fi symbol, it means that your device is connected to a Wi-Fi 6-capable router.
  • CrimpOn's avatar
    CrimpOn
    The WiFi Alliance did no one any favors by creating such confusing names.
    WiFi6 refers to an improvement over WiFi5 for devices using the 5G Frequency WiFi spectrum
    WiFi6E refers to to use of the 6GHz Frequency WiFi spectrum
    Devices labeled WiFi6 are built to use 5G.
