cclark1974's avatar
cclark1974
Wifi continues to drop connection with Google Chromebooks
Im having a real problem, the Wifi on the Google Chromebooks that are connected in my home wifi continually is dropping, I had a conversation with support we made a few changes it still has been an issue.  I had a Google nest before this and havent had these kind of problems before. Any Ideas?
Router Details:
Hardware VersionRBR850
Firmware VersionV3.2.18.1_1.4.14
GUI Language VersionV3.0.0.51_2.1.30.3
Operation ModeRouter
  • FURRYe38's avatar
    Try changing CTS values to 2347?
    Try disabling AX mode on the RBR?
    Has a full power OFF of the RBR and RBS for 30 seconds then back ON been performed?
    • cclark1974's avatar
      cclark1974
      If I disable AX mode Iose Wifi6 for compatible devices right?  I CTS set to 2437 on both 5Ghz and 2 Ghz channels...
      • FURRYe38's avatar
        Yes. Something to try on 2.4ghz only and see if the devices continue to drop connection...
        Not the first time these device have had problems with Orbi AX.
