propheci's avatar
propheci
Wifi Drops - Hardwire fine.
Any luck on this? I think I'm in the same boat. Similar setup as OP: RBR850 with 2 satellites, both on ethernet backhaul.
I've had this setup for 2 years now. It's been fine until the past few months. Now I just wifi drops everyday. Wired connections are fine.
I didn't keep track on when the firmware updates happened. But I didn't change anything else on the network. So now I'm suspicious..
  • FURRYe38's avatar
    What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
    • propheci's avatar
      propheci
      FURRYe38 wrote:
      V4.6.8.2 on router and the 2 satellites.
      Motorola MB7621. I'm with Xfinity.
      3000
      Around 25-30 feet for both. They're both on ethernet backhaul though.
      Auto and 48 on 5Ghz
      No. I'm in a single family house. I can see some of my neighbors' networks but signal is much weaker than mine.
      • propheci's avatar
        propheci
        I was just poking around the logs on the Motorola modem. I see these messages that look suspicious.
        Sat Jul 30 09:13:11 2022   Critical (3)  Started Unicast Maintenance Ranging - No Response received - T3 time-out;CM-MAC=00:40:36:6b:3b:3c;CMTS-MAC=00:01:5c:63:3c:7c;CM-QOS=1.1;CM-VER=3.0;
         Sat Jul 30 09:13:11 2022   Critical (3)  Unicast Maintenance Ranging attempted - No response - Retries exhausted;CM-MAC=00:40:36:6b:3b:3c;CMTS-MAC=00:01:5c:63:3c:7c;CM-QOS=1.1;CM-VER=3.0;
         Sat Jul 30 09:13:11 2022   Critical (3)  16 consecutive T3 timeouts while trying to range on upstream channel 1;CM-MAC=00:40:36:6b:3b:3c;CMTS-MAC=00:01:5c:63:3c:7c;CM-QOS=1.1;CM-VER=3.0;
        Also, I take back what I said about hard wired devices being fine. I do recall now that sometimes they have problems, too.
