VerneArase
Mar 28, 2021Apprentice
Wired backhaul worth it for an AX6000 system?
*Sigh* ... I really have an RBK853 (AX6000) system, even though that's not an option in the forums even now.
I'm thinking of wiring my house for ethernet and I've secured all the cable and equipment needed except for the ethernet switch.
I'm thinking of using a 2x10gb 8x1gb unmanaged switch to connect a Synology 1817+ in the family room downstairs to an iMac 5K w/10gb in my office, 1GB backhaul on the Orbis, and 1GB run up to various parts of the house with the switch living in the utility room downstairs.
The question is: is it worthwhile running the 1GB backhaul on the Orbis replacing a 5ghz AX6000 connection? Now that I've got gigabit service this is beginning to look more worthwhile.
If you're running an ethernet backhaul, what speed difference have you experienced?
I'm a tad apprehensive as I've never run cable through the house before, and my most optimistic plan is to use old existing telephone wire to pull Cat6 and new telephone wire through the house with the hope that when the house was originally wired they didn't wrap it around a nail along the way.
*Really* hoping I don't have to run cable up to the attic and drop cable down from up there.
Any advise on this project would be appreciated.
- DatabaseJaseLuminary
This is a great question and I've fallen into the trap of getting obsessed with how much of our core internet speed (currently a 300Mbps Fibre connection) is distributed around the home. Through general testing I've found that wired devices to the RBR850 get the full 300Mbps and wireless devices connected to the RBR850 get around 250Mbps (at these speeds Wifi6 isn't much of a benefit). The RBS850 gives wired devices about 250Mbps and wireless devices about 200Mbps (these vary by device type; PC, iPad, iPhone, etc.).
I have tested with ethernet backhaul and that makes the RBS850 show similar speeds to devices as if they were connected to the RBR850 directly (wired and wireless). Depending on needs using wireless backhaul is sufficient so long as the signal/distance between the router and the satellite is strong/not too far.
What I finally made myself think about is what benefit is there of getting the optimum speeds at the RBS850? A 4K video stream needs about a 50Mbps so is that my baseline? Downloading games/updates that run into many GBs then speed optimisation is important but does a few extra minutes waiting for a download to finish mean running ethernet backhaul is worth it?
I think it really comes down to what you want. I can relate to the frustration that comes when paying for a gigabit service and seeing an Orbi satellite only giving 400-500Mbps over wireless backhaul but ask yourself why you need the full gigabit speeds distributed everywhere. Remember that Orbi AX system has 2400Mbps wireless backhaul with a good signal between router and satellite,
Now if you're satellite is only giving 50-100Mbps, or even less, then running ethernet backhaul would be worthwhile but before going to that trouble see if you can move them closer.
- VerneAraseApprentice
DatabaseJase wrote:This is a great question and I've fallen into the trap of getting obsessed with how much of our core internet speed (currently a 300Mbps Fibre connection) is distributed around the home. Through general testing I've found that wired devices to the RBR850 get the full 300Mbps and wireless devices connected to the RBR850 get around 250Mbps (at these speeds Wifi6 isn't much of a benefit). The RBS850 gives wired devices about 250Mbps and wireless devices about 200Mbps (these vary by device type; PC, iPad, iPhone, etc.).
Yeah, I got all the ethernet cable and stuff but looking at some of the wiring I found RJ-11 cable tacked in runs along the walls, and am wondering if it's worth it to run ethernet everywhere.
Certainly would be more worthwhile if the mesh nodes supported something more than 1gbps - but doing all this would only incrementally increase throughput for most nodes. I could get 10gbps between my office iMac and the Synology downstairs - which would greatly increase the 60-66 MB/sec I currently get - but really that's only an advantage during backups and restores as the Synology is really primary backup for a Thunderbolt connected Drobo 8D in my office.
In general I don't need high throughput for this connection - though one time I did when I had to reformat the Drobo to increase its single volume storage capacity, and that incident did require restore of some 32 TB of data. That would be more painful today, but again I could do what I did then and haul the Synology upstairs and direct connect the iMac and Synology and now I could get the full 10gpbs which would make the restore run at nearly a gigabyte/sec (my old iMac didn't have a 10gpbs ethernet port).
The thing that would make the entire project more worthwhile would be if 10mbps was ubiquitous - but most ports even now only support 1gbps and 10 gig equipment (like large multiport switches) are still really expensive.
Wired connections tent to have been performance over wireless as there isn't much variables with wired connections vs wireless.
VerneArase wrote:*Sigh* ... I really have an RBK853 (AX6000) system, even though that's not an option in the forums even now.
- bullm00nVirtuoso
Yes, bummer about that dropdown box that doesn't include our gear.
When I first set up our AX6000, I tried my single satellite wired and wireless backhaul and there was not an obvious difference when using OOKLA to test speeds. I only tried this over a couple of days, but either seemed to work as well. My best speeds with my iPhone were in the 700s. Depending on where I am in the house I can get anywhere from 350-750 Mbps. I have the wire in place, so I could switch back to wired but for now I'm leaving it wireless. Theoretically the wireless backhaul should be capable of higher speeds. I should connect a wired device to the wireless satellite and test setup that for a better comparison that would isolate the backhaul performance. My wired devices are getting 950 Mbps on a good day. :) So I will do that test when I have some time.Good luck with your wiring. If I were doing it, I'd put the wire in place even if wireless works - at some point you may want to do something differently and I figure while you are in the middle of pulling cable, may as well do all of it and get it out of the way.
I'm getting about 680-720/41.2-41.6 mbps through a LAN cable from my office satallite to my iMac 5K, but about 941/39.5 directly out of the main router (now that Speedtest is working again).
The office iMac to the Synology downstairs is a pretty consistent 60-66 MB/sec which ethernet should improve to a little less than a gigabyte.
If you use ethernet backhaul, does the Orbi free up the backhaul radios for other devices?
I'm thinking of putting a 2 10gb / 8 1gb unmanaged switch in the utility room with a 10 gb and 1 gb going to the Synology and Orbi router in the family room, a 10 gb and 1gb going up to my office for the iMac and Orbi satellite, a 1gb going up to my wife's office, and 1 gb going up to the living room for the Living Room satellite. That'll get spread by switch to the various living room devices and daisy chained to the dining room where my wife has a computer and we have another iMac 5K. The Living Room to Dining Room feed will have to go up in the attic with drops down two walls, an interior and an exterior.
Can you run the backhaul through a switch, or does each router <-> satellite connection require it's own (topologically speaking) wire? If that's the case, that would mean two additional 1 gb runs from the router to each of the satellites in the Living Room and Office.
No you can run a switch in between.
I have 1 8 port switch off the RBR, then two other sub 5 port switches after that. One RBS ethernet connected to each of those sub switches. Daisy Chaining switchs works fine.
- bullm00nVirtuoso
fasa33 wrote:The steps that you taken there are impressive but in my opinion ethernet will never change the speed as much as may be you are expecting from it seehere the details about it.
It certainly depends on the weakest link, but do you not think 1Gbps is better than a 10Mbps link - if the attached devices need the speed or especially if many devices share that pipe? And your link to office chairs is not likely illuminating. :smileyfrustrated:
