lxu2011ct
Aug 20, 2025Aspirant
Wired connected Mac Mini with RBR 750 has no internet connection
Hi, My Mac Mini is connected via Ethernet to the RBR750 router and serves as a document server for our home network. All other devices can access it, whether they're connected wirelessly or by ca...
- Aug 21, 2025
Hi, I sent my question to Copilot.microsoft.com and got a list of Key Possibilities to investigate. The first one "IP Reservation vs. Static IP Conflict" fixed my problem. It turned out that the Mac Mini was accidently set to use Manually instead of DHCP, which messed up the DNS. After the correction, the Mac has the internet connection with ethernet cable. Thank you all for your help!
L
Aug 21, 2025Guru - Experienced User
Contact Apple support for additional help in information regarding there products. If other devices are working and this one isn't, this one use needs to be looked at.
lxu2011ct
Aug 21, 2025Aspirant
I still believe the issue was caused by some incorrect settings I configured on the RBR750. The Mac Mini isn't to blame. Thanks.
