theBrick89
Oct 23, 2019Star
WPA3 issues
I just repalced my RBK52 to RBK852 and so far everything works great except major WPA3 hiccup I thought WPA3 supposed to be a backward compatible but some devices cannot connect the network if I set...
kickingyourself
Apr 01, 2020Aspirant
Product (not included in the dropdown list): RBS850 Orbi Satellite
Firmware: V3.2.10.11_1.2.12
Upgraded firmware on the router and satellite. Both rebooted successfully. I updated the security protocol to WPA3-Personal, and now the satellite no longer appears in the network, not on the app or the UI login screen. Rebooting and resetting has not solved the issue.
Apr 01, 2020Guru - Experienced User
I just checked mine. Mine was using WPA2 and AES only in AP mode. I first turned off the RBSs, changed to WPA3 and applied the change. I powered on the two RBS one at a time. They both appeared eventually in the RBRs status page as satellites and were connected wirelessly.
kickingyourself wrote:Product (not included in the dropdown list): RBS850 Orbi Satellite
