theBrick89
Oct 23, 2019Star
WPA3 issues
I just repalced my RBK52 to RBK852 and so far everything works great except major WPA3 hiccup I thought WPA3 supposed to be a backward compatible but some devices cannot connect the network if I set...
Apr 01, 2020Guru - Experienced User
I just checked mine. Mine was using WPA2 and AES only in AP mode. I first turned off the RBSs, changed to WPA3 and applied the change. I powered on the two RBS one at a time. They both appeared eventually in the RBRs status page as satellites and were connected wirelessly.
kickingyourself wrote:Product (not included in the dropdown list): RBS850 Orbi Satellite
Firmware: V3.2.10.11_1.2.12
Upgraded firmware on the router and satellite. Both rebooted successfully. I updated the security protocol to WPA3-Personal, and now the satellite no longer appears in the network, not on the app or the UI login screen. Rebooting and resetting has not solved the issue.
AspireTech
May 02, 2020Initiate
Uugh, wish they would update rbs850 fw to support wpa2/wpa3 mixed mode. Can't secure the rest of the network on wap3 until they do this.
