DeaneHornsby
Nov 03, 2025Tutor
Zoom is continously displaying low bandwidth and screen sharing lags
I've been trying to solve a similar issue on RBR850 with three RBS850. running Zoom. Zoom is continously displaying low bandwidth and screen sharing lags (although it get there in the end) I followe...
- Nov 04, 2025
DeaneHornsby wrote:
Hi there, I'm using a coporate VPN and logging into Zoom App on my Mac
The VPN might be the real problem here.
Do you see this if you make a zoom call when not logged into the VPN???
CrimpOn
Nov 03, 2025Guru - Experienced User
There is newer firmware:
https://kb.netgear.com/000066592
As an observation, people seem less interested in diagnosing problems with older firmware versions.
- StephenBNov 04, 2025Guru - Experienced User
As an observation, people seem less interested in diagnosing problems with older firmware versions.I'd also start by updating the firmware.
Does the problem happen only on wifi? Or is this also an issue with ethernet?
- DeaneHornsbyNov 05, 2025Tutor
Thanks CrimpOn, the corporate VPN was the culprit. I'm going to update the firmware anyhow as per your advise as it old. Relatively new to Orbi I'd been using update firmware which was reporting I had the latest, not realising it was the latest for that Orbi release. I'm now working through the process and correct squence of manual updating the firmware.
