DeaneHornsby
Nov 03, 2025Tutor
Zoom is continously displaying low bandwidth and screen sharing lags
I've been trying to solve a similar issue on RBR850 with three RBS850. running Zoom. Zoom is continously displaying low bandwidth and screen sharing lags (although it get there in the end) I followe...
- Nov 04, 2025
DeaneHornsby wrote:
Hi there, I'm using a coporate VPN and logging into Zoom App on my Mac
The VPN might be the real problem here.
Do you see this if you make a zoom call when not logged into the VPN???
CrimpOn
Nov 03, 2025Guru - Experienced User
There is newer firmware:
https://kb.netgear.com/000066592
As an observation, people seem less interested in diagnosing problems with older firmware versions.
Nov 04, 2025Guru - Experienced User
CrimpOn wrote:There is newer firmware:
I'd also start by updating the firmware.
Does the problem happen only on wifi? Or is this also an issue with ethernet?
