DeaneHornsby
Nov 03, 2025Tutor
Zoom is continously displaying low bandwidth and screen sharing lags
I've been trying to solve a similar issue on RBR850 with three RBS850. running Zoom. Zoom is continously displaying low bandwidth and screen sharing lags (although it get there in the end) I followe...
- Nov 04, 2025
DeaneHornsby wrote:
Hi there, I'm using a coporate VPN and logging into Zoom App on my Mac
The VPN might be the real problem here.
Do you see this if you make a zoom call when not logged into the VPN???
Nov 04, 2025Guru - Experienced User
FURRYe38 wrote:Enable SIP ALG and test?
FYI, Zoom calls from the Zoom App and web browser don't use SIP. Which appears to be the case here (connecting from a Mac).
But if DeaneHornsby is dialing in from a SIP device, then this test would be useful.
I leave SIP ALG enabled on all my routers. Haven't had any problems with it being enabled and Zoom and Teams all work finr. Last meeting with NG was over zoom and worked well with my Mac Book Pro 2018. Why I suggested testing it anyways. Also SIP ALG is something we test for in beta projects to help check this as well.
- StephenBNov 04, 2025Guru - Experienced User
It's not possible to test if it is working as designed, unless you analyze wireshark traces of actual SIP calls. I guess you can see if SIP calls go through or not, but I don't think that tells you much without a trace. We know that the ALG can interfere with infrastructure for NAT traversal, so it might be working as intended even when calls don't go through.
You can see if it misbehaves on non-SIP traffic, though seems really unlikely unless someone is using port 5060 or 5061 for another purpose. The zoom video app (and browser) conferences don't use those ports. So I don't think that test is useful here, unless DeaneHornsby happens to be using a VOIP phone to connect to the conference.
- FURRYe38Nov 04, 2025Guru - Experienced User
We do test with SIP ALG enabled and disabled on all calls and online meetings. Haven't seen any issues to date with SIP ALG enabled or disabled. I believe that some SIP ALG issues seen historically may have been resolved. And NH routers have SIP ALG enabled by default.
Lets have the user give feedback though.
- DeaneHornsbyNov 04, 2025Tutor
I'll re enable SIP ALG, set to open and re-try. I'd looked up lots of sites on best config for Zoom/Orbi and most siad disable it, hence why I disabled
DeaneHornsby wrote:
Hi there, I'm using a coporate VPN and logging into Zoom App on my Mac, not dialing from a SIP devlice
