DeaneHornsby
Nov 03, 2025Tutor
Zoom is continously displaying low bandwidth and screen sharing lags
I've been trying to solve a similar issue on RBR850 with three RBS850. running Zoom. Zoom is continously displaying low bandwidth and screen sharing lags (although it get there in the end) I followe...
- Nov 04, 2025
DeaneHornsby wrote:
Hi there, I'm using a coporate VPN and logging into Zoom App on my Mac
The VPN might be the real problem here.
Do you see this if you make a zoom call when not logged into the VPN???
Nov 04, 2025Guru - Experienced User
DeaneHornsby wrote:I've been trying to solve a similar issue on RBR850 with three RBS850. running Zoom. Zoom is continously displaying low bandwidth and screen sharing lags (although it get there in the end)
If this still happens after you update the firmware, then it would be good to know
- Whether you are connecting to work-related zoom conferences, or whether these are personal. Some companies host their own Zoom servers, and it would be good to know if that is a possibility here.
- Your ISP and internet connection type (fiber, cable, satellite,mobile broadband). Some ISPs will dynamically adjust your upload and download speeds, and that could also explain what you are seeing.
- DeaneHornsbyNov 04, 2025Tutor
I'll try the firmware update next - after following a few of the suggestions - especially the VPN as this is work related - Zoom is a work app not personal.
ISP is Optus - NBN which is via Hybrid Fibre-Coaxial (HFC nbn). The nbn connetion box - Network Termination Device (Arris CM8200) - is owned by our National Broadband Network and specific to my apartment's address, so I connect the Orbi RBR into the NTD via its WAN connection.
