DeaneHornsby
Nov 03, 2025Tutor
Zoom is continously displaying low bandwidth and screen sharing lags
I've been trying to solve a similar issue on RBR850 with three RBS850. running Zoom. Zoom is continously displaying low bandwidth and screen sharing lags (although it get there in the end) I followe...
- Nov 04, 2025
DeaneHornsby wrote:
Hi there, I'm using a coporate VPN and logging into Zoom App on my Mac
The VPN might be the real problem here.
Do you see this if you make a zoom call when not logged into the VPN???
Nov 04, 2025Guru - Experienced User
FURRYe38 wrote:Enable SIP ALG and test?
FYI, Zoom calls from the Zoom App and web browser don't use SIP. Which appears to be the case here (connecting from a Mac).
But if DeaneHornsby is dialing in from a SIP device, then this test would be useful.
DeaneHornsby
Nov 04, 2025Tutor
Hi there, I'm using a coporate VPN and logging into Zoom App on my Mac, not dialing from a SIP devlice
- StephenBNov 04, 2025Guru - Experienced User
- DeaneHornsbyNov 04, 2025Tutor
Hi StephenB, thanks for the tip, will try that this evening (Im in Sydney, Australia)
- StephenBNov 05, 2025Guru - Experienced User
Great city - I had a chance to visit it some years ago, and wished I had more time to explore it.
Back to this - I had a similar issue some years ago - our corporate VPN infrastructure just didn't provide enough bandwidth. I didn't have to use the VPN for work video conferencing, but it was annoying because I couldn't access corporate documents while on work video calls, since those were only available when I was on the VPN.
Very likely to be the VPN here too, and if that is the situation you'll need to work with your employer to solve it.
- DeaneHornsbyNov 05, 2025Tutor
Hi StephenB, I logged in to Zoom outside of the corporate VPN and it didn't lag, it worked fine. Many thanks for your advice.
