DeaneHornsby
Nov 03, 2025Tutor
Zoom is continously displaying low bandwidth and screen sharing lags
I've been trying to solve a similar issue on RBR850 with three RBS850. running Zoom. Zoom is continously displaying low bandwidth and screen sharing lags (although it get there in the end) I followe...
- Nov 04, 2025
DeaneHornsby wrote:
Hi there, I'm using a coporate VPN and logging into Zoom App on my Mac
The VPN might be the real problem here.
Do you see this if you make a zoom call when not logged into the VPN???
DeaneHornsby
Nov 04, 2025Tutor
Hi there, I'm using a coporate VPN and logging into Zoom App on my Mac, not dialing from a SIP devlice
Nov 04, 2025Guru - Experienced User
DeaneHornsby wrote:Hi there, I'm using a coporate VPN and logging into Zoom App on my Mac
- DeaneHornsbyNov 04, 2025Tutor
Hi StephenB, thanks for the tip, will try that this evening (Im in Sydney, Australia)
- StephenBNov 05, 2025Guru - Experienced User
Great city - I had a chance to visit it some years ago, and wished I had more time to explore it.
Back to this - I had a similar issue some years ago - our corporate VPN infrastructure just didn't provide enough bandwidth. I didn't have to use the VPN for work video conferencing, but it was annoying because I couldn't access corporate documents while on work video calls, since those were only available when I was on the VPN.
Very likely to be the VPN here too, and if that is the situation you'll need to work with your employer to solve it.
- DeaneHornsbyNov 05, 2025Tutor
My IT team is going to see if they can allow split tunneling for Zoom on the corporate VPN. In the meantime I've learned to live with the lag... at least it works :)
