Josephdeck
Oct 06, 2025Aspirant
2.4 GHz device issues RBR760
Hello, I have started experiencing issues with devices using 2.4 ghz. Most recently my GE washer and dryer. When I bring up the ORBI app is shows them connected with adequate bandwidth. They are...
CrimpOn
Oct 07, 2025Guru - Experienced User
Josephdeck wrote:the ORBI app is shows them connected with adequate bandwidth
As you have no problem using the GE app to connect the appliances to the network and the network shows them connected, methods used to get a device connected when the smartphone app is poorly written are not relevant to the problem. (i.e. they recognize the 2.4G network and connect. There is no reason to find a "work around".)
Does GE have a user forum where customers discuss using the app with their GE appliances?
