Lidelse
Aug 23, 2025Aspirant
320 Mhz Channel width on RBE971
My RBE971 and 2 RBE970 will not broadcast 6ghz in 320 mhz channel width. I have some wifi 7 stuff and mostly wifi 6 or 6e and then some older on 5ghz/2.4 for like streaming/IoT stuff. Regardl...
Lidelse
So there are two Samsung galaxy s25 us unlocked variants. A pc with an Intel killed be1750x using 23.150.0 I believe is the driver. It's whatever Intel has on their site. No further driver available on Intel driver support assistant. Different pc with I to be200ngw same driver. The killer one doesn't change 320 or not if I use the killer performance suite. But the killer software not just rhe driver. Which is the Intel wireless driver anyway janks stuff up so I don't use it. It doesn't change off 269 if there are no satellites or satellites either. I have factory reset this system also to see if it helped. And mlo is turned on for backhaul and it showing as 5 P 5gj for backhaul connection for the one rbs on wireless. The other is wired.
