jefferis
Dec 30, 2025Guide
6 G to Satellite is slow
I ran a speedtest of my Orbi97 in the interface and it is showing 66mbps download speed. My laptop has a 6G connection to a satellite with a strong signal, and while it normally gets pretty good spe...
jefferis
Sep 12, 2026Guide
What is a 30-30-30 Reset?
Sep 12, 2026Guru - Experienced User
With the router plugged in and powered on, depress the reset button for 30 seconds. This button is usually a tiny dot recessed into the back of the router. You may need a jeweler's screwdriver or a bent paperclip to access it.
While still holding down the button, unplug the router from its power source for another 30 seconds.
With the reset button still held down, turn the power back on and hold for another 30 seconds.
