dilhaikpathar
Aug 31, 2025Aspirant
770 series coverage
I'm also facing same issues .
Aug 31, 2025Guru - Experienced User
What issues are you facing? You'll need to give more details on the problems your having.
How are you determining the new system has less coverage?
What kinds of devices do you have connected?
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
How many RBS are deployed?
What is the distance between the router 📡 and satellite(s)🛰️? 30 feet or more is recommended in between RBR 📡 and RBS 🛰️ to begin with depending upon building materials when wired or wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite ‌‌🛰
What channel configurations are currently set on the router?
