jhey
Apr 27, 2026Aspirant
771 mesh router and satellite - no seamless transitions
I have the 77X mesh router and satellites, and whenever I move from upstairs (where the main router is) to ground floor (satellite location), my phone ‘s wifi disconnects and takes a long time to rec...
Apr 27, 2026Guru - Experienced User
How big is the home? How many satellites? How many levels?
Could be that the phones built in roaming protocol doesn't call for them to switch to a stronger signal yet. If the older AC tech didn't broadcast as far, they might not roam as often with a newer/faster system.
jhey
2600sqrf , two satellites, basement, ground, upper level.
- FURRYe38Apr 27, 2026Guru - Experienced User
What is the distance between the router 📡 and satellite(s)🛰️
For that size of home, the RBR and just one should work well.
Can you try to see if turning OFF one RBS results is same tranisition issues?
