jhey
Apr 27, 2026Aspirant
771 mesh router and satellite - no seamless transitions
I have the 77X mesh router and satellites, and whenever I move from upstairs (where the main router is) to ground floor (satellite location), my phone ‘s wifi disconnects and takes a long time to rec...
jhey
iPhone 15 Pro
CrimpOn
Apr 27, 2026Guru - Experienced User
Thanks for the quick reply. (sigh) iPhone 15 Pro does not support WiFi7, so that is not likely to be relevant.
Google search seems to indicate that users have no method of altering the iPhone 15 roaming aggressiveness:
The Original Post stated this:
jhey wrote:my phone ‘s wifi disconnects and takes a long time to reconnect
That seems to indicate that the iPhone is not "roaming" at all on the 770 system.
Anything else you can test with? (laptop? tablet? old iPod?)
(sorry to be ignorant about Apple products.....) On my Android and Windows devices there are applications that can scan the WiFi environment and report the signal level of every WiFi access point they can sense. For example, my phone reports that my Orbi router and three satellites measure:
- -37dB
- -57dB
- -65dB
- -70dB
(the phone is connected to the router that is 4ft. away and appears to be at -37dB.)
