IntegraRG
Oct 20, 2025Aspirant
Add a 973 Router to a current 970 Mesh System
I bought 2 Orbi 970 3-pack Mesh Systems and I want to set them up as one fully-meshed network in 4 different construction trailers. One router is setup already with one 970 satellite hard-wired for ...
- Oct 20, 2025
Yes, it should work.
CrimpOn
Oct 20, 2025Guru - Experienced User
An Orbi router cannot be a satellite. Some companies designed their WiFi mesh systems so that every unit can be either the router or a satellite. Netgear did not. A router is always a 'router'.
- If it is in 'router mode', then all of the router features are enabled. (Armor, DHCP, OpenVPN, Access Control,...... etc.
- If it is in 'access point mode', then most of those features are disabled.
https://kb.netgear.com/000061277/Which-features-are-disabled-on-my-Orbi-router-when-it-is-set-to-AP-Mode
However, the router and any satellites attached to it remain a unique WiFi system.
As long as users do not carry mobile devices around between buildings, they will never know. Those that do will quickly get used to "oh. WiFi pathetic. Disconnect & reconnect" (5 seconds).
Netgear has an entire line of commercial WiFi networking products. Have no experience with them.
