MattEyde's avatar
MattEyde
Also join "NTGRB-H_…."?
I’ve had non-stop issues with my Orbi RBE771 WiFi 7 mesh system. I recently started getting this message when new devices connect to my network…this was after a case I had open with Netgear for about 6 weeks. I’m starting to regret this purchase. Anyone have a fix for this:
  • I have a RBE771 router running firmware version 10.5.19.5 and two satellites running the same firmware, with 5ghz and 6ghz networks.
  • CrimpOn's avatar
    CrimpOn
    There is nothing to fix.  Netgear Orbi routers have a separate WiFi network that is used to connect the router and satellites, that people describe as the "backhaul".  On the original WiFi5 and the newer WiFi6 systems, this network had a fairly unique name and very long password.  Those routers did not broadcast the network SSID, and thus those networks were not picked up by user WiFi devices.  The newest WiFi7 Orbi models
    • Assign a unique name to this network consisting of "NTGRBH" (Netgear Back Haul) plus a long unique number.  The password is also incredibly long so that no user will ever be able to guess it.
    • However, the SSID of this network is broadcasted, and thus consumer devices can detect it and suggest that users connect to it.  With a password that they can never guess, it is impossible to connect to this network.
    • Netgear was informed of the issues this change has caused for users.  As far as I am aware, there has never been a published explanation for this decision, nor has netgear issued new firmware to fix it.
    Just ignore it.
  • KevinLiT's avatar
    KevinLiT
    NETGEAR Moderator
    Hello MattEyde​,
    Welcome to the NETGEAR Community!
    I understand that you are getting notifications to add your devices to an SSID that you do not recognize with firmware version 10.5.19.5. To resolve this issue, please update your firmware to the latest released firmware version 10.5.20.3.
    Please navigate to the link below to download the most current firmware version for your system:
    RBE770 / RBE771 Firmware Version 10.5.20.3 - NETGEAR Support
    Navigate to the link below for instructions on how to manually update your Orbi system:
    How do I manually upgrade firmware on my Orbi router using orbilogin.com? - NETGEAR Support
    Best,
    Kevin
    Community Team
