Simondo1982
May 07, 2025Tutor
blamed everything other than the router over 9 months
Having this exact same problem, I blamed everything other than the router over 9 months but after a lot of messing about it's still hopeless. They won't refund me (apparently nether dont do that) an...
Simondo1982
May 15, 2025Tutor
I’m in the UK, how do I check that?
liamscor
May 15, 2025Luminary
Here is a link to disable the 20/40MHz: https://kb.netgear.com/30228/How-do-I-disable-20-40-MHz-coexistence-on-my-NETGEAR-router
Then try setting the "2.4GHz" to one of the non-overlapping "European" channels these are channels 1, 7 & 13 in Europe. "I have mine set to channel 13".
More info here: https://kb.netgear.com/1027/Selecting-wireless-channels
Then power cycle the entire system and see how you get on.
