Simondo1982
May 07, 2025Tutor
blamed everything other than the router over 9 months
Having this exact same problem, I blamed everything other than the router over 9 months but after a lot of messing about it's still hopeless. They won't refund me (apparently nether dont do that) an...
Simondo1982
May 15, 2025Tutor
HI
Thankyou for this.
good point about the satellites, the only thing is that I do have a couple of blackspots in my house (hence my perceived need for a mesh system). it is probably just about 30 foot if I place one at the extremity of my house, but if I do that then the base cant find it! I will try taking the satellites offline for a few days and see what happens re general connectivity, at least that will solve one problem!
my modem is call Netominia - I'm online with Youfibre.
Really appreciate how clear your advice is and the time you have taken to help me.
- FURRYe38May 15, 2025Guru - Experienced User
Ok, please try with the RBR unit only, then after a few days, try turning on 1 RBS. Place out at 30feet ish range and place where the signal shows as GOOD on the RBRs web page. May need to move it around a bit and give a few minutes for the status to change on the RBRs web page.
