Zirene22
Jun 22, 2025Guide
Blocked/Not-Blocked Devices
Late last night I found a UI in the app that allowed me to "block" devices from accessing a specific satellite (showed a device list for the specific satellite with a blue background). This sounded l...
Zirene22
Jun 22, 2025Guide
That is understood. The issue is that the method by which this device was blocked (blocked from accessing a single satellite) is no longer available. The mobile app shows the device is not blocked in any way though it shows no wifi utilization (see image), and I can only set it to be blocked there. The Web GUI shows it is blocked with no option to unblock.
michaelkenward
Jun 23, 2025Guru - Experienced User
Can you see the Apple TV in the list of Attached devices on the router?
Zirene22 wrote:The Web GUI shows it is blocked with no option to unblock.
That is now something you have to control with the app.
- Zirene22Jun 24, 2025Guide
I can see the device connected, ironically to the Basement satellite. The wifi icon is "gray" showing that it does not have full access like other devices. You can see this in the screenshot I posted above.
