birdsafe
Oct 10, 2025Aspirant
Bridge Mode?
Going to be setting up a new Orbi 770 system in my home. Attaching it to a Comcast Router/Modem. Am I better off adding a 2nd WFi network in home or turning on bridge mode on the comcast router and...
- Oct 10, 2025
Best to disable the wifi radio on the ISP router and if you can get the ISP gateway in to bridge or modem only mode, would be best.
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
https://kb.netgear.com/30187/How-to-fix-issues-with-Double-NATCouple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router.
Static IP Address Configuration for AP Mode | NETGEAR Communitieshttps://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try option #2 first...
Oct 10, 2025Guru - Experienced User
Couple of options,
- birdsafeOct 10, 2025Aspirant
Thanks - I have been able to use bridge mode using my current Nighthawk router but I wasn't sure which mode would be more efficient for the Orbi system. I currently use the Nighthawk as a second router/AP and it drives me nut sometimes having two SSIDs.
- FURRYe38Oct 10, 2025Guru - Experienced User
Keep it simple. The Orbi system, you'll only have one SSID to connect everything with. Though for some additional needs you can have a separate IoT work for those problematic devices.
