donawalt
Jun 28, 2025Mentor - Experienced User
BUG: KERNEL CRASH in 9.13.1.2, Orbi 970
After being up about 28 hours, one of my 970 satellites did a restart. The bug log reports that the reason was a kernel crash.
It was at about 1:30 AM local time, so little or no action going o...
Jun 28, 2025Guru - Experienced User
Will need to know what you did after FW was updated on the system.
Updated manually or via AU?
FW updated and you continued to use the system after the reboot?
After FW updated, power cycled the system OFF then back ON and continue?
Factory reset and setup from scratch after FW was updated?
Jul 03, 2025Guru - Experienced User
Would need some feedback on these questions:
- donawaltJul 03, 2025Mentor - Experienced User
Updated manually or via AU? Manually
FW updated and you continued to use the system after the reboot? Reboot from update, then PC everything
After FW updated, power cycled the system OFF then back ON and continue? Yes
Factory reset and setup from scratch after FW was updated? No
