donawalt
Jun 28, 2025Mentor - Experienced User
BUG: KERNEL CRASH in 9.13.1.2, Orbi 970
After being up about 28 hours, one of my 970 satellites did a restart. The bug log reports that the reason was a kernel crash.
It was at about 1:30 AM local time, so little or no action going o...
Saner
Nov 04, 2025Apprentice
FYI : The zip files for fw 9.13.2.1 are updated now. Both RBR + RBS zip files are correct on NG side. Please download and upgrade. Try this version. If RBR craches continue, request a RMA from NG.
- dkarataievNov 04, 2025Star
Unfortunately, the new firmware didn't resolve the issue—same problem.
- FURRYe38Nov 04, 2025Guru - Experienced User
Have you factory reset the system and setup from scratch to check this?
What all do you have connected to 970 series system?
I just reset everything, we'll see if that helps. What do you mean by connected to 970?
