donawalt
Jun 28, 2025Mentor - Experienced User
BUG: KERNEL CRASH in 9.13.1.2, Orbi 970
After being up about 28 hours, one of my 970 satellites did a restart. The bug log reports that the reason was a kernel crash.
It was at about 1:30 AM local time, so little or no action going o...
Saner
Nov 04, 2025Apprentice
FYI : The zip files for fw 9.13.2.1 are updated now. Both RBR + RBS zip files are correct on NG side. Please download and upgrade. Try this version. If RBR craches continue, request a RMA from NG.
dkarataiev
Nov 04, 2025Star
Unfortunately, the new firmware didn't resolve the issue—same problem.
- FURRYe38Nov 04, 2025Guru - Experienced User
Have you factory reset the system and setup from scratch to check this?
What all do you have connected to 970 series system?
- dkarataievNov 04, 2025Star
I just reset everything, we'll see if that helps. What do you mean by connected to 970?
What all devices are connected to the system? Phones,pads and etc...
Let us know if this happens again.
