donawalt
Jun 28, 2025Mentor - Experienced User
BUG: KERNEL CRASH in 9.13.1.2, Orbi 970
After being up about 28 hours, one of my 970 satellites did a restart. The bug log reports that the reason was a kernel crash.
It was at about 1:30 AM local time, so little or no action going o...
dkarataiev
Nov 04, 2025Star
Unfortunately, the new firmware didn't resolve the issue—same problem.
Nov 04, 2025Guru - Experienced User
Have you factory reset the system and setup from scratch to check this?
What all do you have connected to 970 series system?
dkarataiev wrote:Unfortunately, the new firmware didn't resolve the issue—same problem.
- dkarataievNov 04, 2025Star
I just reset everything, we'll see if that helps. What do you mean by connected to 970?
- FURRYe38Nov 04, 2025Guru - Experienced User
What all devices are connected to the system? Phones,pads and etc...
Let us know if this happens again.
Well, I have all the typical things: phones, laptops, etc. The router just restarted again :( This is after installing the new firmware, resetting, and setting everything up again.
