Scoobydoo987
Nov 30, 2025Aspirant
Can’t communicate between wireless bands on a satellite
Really disappointed with brand new 373 +2 satellite kit. Hoping I’ve made a rookie mistake but… My issue seems to be specific to satellites. Client devices on the same SSID can’t communicate betwe...
Scoobydoo987
Dec 01, 2025Aspirant
Yes main wlan (IoT and Guest are switched off). I could open up the IoT and put something on it I guess, I'll come back to you on that!
have opened up a case with support and hope they are reading this thread since I sent it to them. The last advice from them I got was to hard-reset and then re-sync the satellite (ie set it up like it was brand new), which didn’t make any difference.
Thanks for testing, I'll be interested to see if it’s different on another model.
- FURRYe38Dec 01, 2025Guru - Experienced User
K, will check my system out. Let us know if IoT network changes anything.
