Scoobydoo987
Nov 30, 2025Aspirant
Can’t communicate between wireless bands on a satellite
Really disappointed with brand new 373 +2 satellite kit. Hoping I’ve made a rookie mistake but… My issue seems to be specific to satellites. Client devices on the same SSID can’t communicate betwe...
Scoobydoo987
Dec 03, 2025Aspirant
Thank you so much for trying this. I appreciate it may not be feasible, but if possible – would you mind changing the network to 192.168.4/24 and repeating - that’s probably the only remaining difference.
I’ve moved my satellite somewhere else since the radios on these don’t seem to be quite as powerful as the devices I was using before.
I’m wondering if it may be something to do with the way the backhaul had established on mine. If you could take a screenshot of how the backhaul is working on your statistics that would be great.
I will retest later on today and post again.
Dec 03, 2025Guru - Experienced User
Can you try 192.168.1/24? What I had my system using yesterday. Also NG couldn't reproduce this either.
I let my RBS fully connect and it showing being connected MLO to the RBR, 2.4+5Ghz before I started testing. I presume your RBS is doing the same? Should be.
