Scoobydoo987
Nov 30, 2025Aspirant
Can’t communicate between wireless bands on a satellite
Really disappointed with brand new 373 +2 satellite kit. Hoping I’ve made a rookie mistake but… My issue seems to be specific to satellites. Client devices on the same SSID can’t communicate betwe...
Scoobydoo987
Dec 03, 2025Aspirant
Unfortunately not without reconfig the external gateway which is not something I can easily do at the moment. I’ve just tested it again, and I still have the same problem. I’ll get a Windows device and try from that tmrw.
The backhaul has said itself up as 2.4 and 5 and status says ‘good’.
If it’s possible to get NG to test with main wifi set to 192.168.4/24, and external gateway on 192.168.1/24 that would be great. To re’ip my network after spending a week stabilizing it is going to be a bit painful.
perhaps I have a faulty satellite…
