Bmog1213's avatar
Bmog1213
Can’t generate device list after 12 hours post reboot
Same issue here , can’t generate device list after 12 hours post reboot !!! App recognizes the satellite however lots of devices including tp link light switches seems offline even though I clearly can control them , seems to me unusual ? What to do ?
  • I have same issue and factory reset solved the issue yet 12 hours later back in same place the web app can’t generate device list
  • FURRYe38's avatar
    Yes is a known issue and is being worked on. NG IS aware of it. Orbi App should be working. It's the WEB UI that is failing. Were all waiting on NG to release the fix. No idea of when that will be. Something you can contact NG support about.
    Failing on mine as well.
