JimS-CLT
Nov 17, 2025Aspirant
Can't get my ios device to connect to Orbi 770 VPN.
I used the mobile device ovpn file vanilla except I changed the "verb" option to 3.... Here's my log file: [Nov 17, 2025, 13:45:32] Connecting to************ via UDP [Nov 17, 2025, 13:45:32] E...
CrimpOn
Nov 17, 2025Guru - Experienced User
Is the OpenVPN Connect app the most recent? (version 3.7.2)
It would be helpful if you could try a non-Apple device.
Internet search for that error message seems to suggest putting a line in the configuration file ("ifconfig"), which does NOT appear in the smartphone.ovpn file that the Orbi generates.
- JimS-CLTNov 17, 2025Aspirant
That's what ChatGPT said, but apparently the ifconfig directive must be sent from the host in this case. I'm on hour 5 of this, the first 4 with ChatGPT.
OpenVPN is 3.7.2
I don't know how to open a ticket. I'll try
