JimS-CLT
Nov 17, 2025Aspirant
Can't get my ios device to connect to Orbi 770 VPN.
I used the mobile device ovpn file vanilla except I changed the "verb" option to 3.... Here's my log file: [Nov 17, 2025, 13:45:32] Connecting to************ via UDP [Nov 17, 2025, 13:45:32] E...
Nov 19, 2025Guru - Experienced User
Any progress on this?
Can you get the debug logs from the RBR when this issue happens?
What was the reason for changing to this value? "I used the mobile device ovpn file vanilla except I changed the "verb" option to 3"
- JimS-CLTNov 19, 2025Aspirant
Tech support asked me to upgrade my router to a higher (apparently not published) rev level. I just now got home. I'll do it now. ChatGPT suggested making the verb option 3 to get more detailed error messages.
- FURRYe38Nov 19, 2025Guru - Experienced User
This a FW version?
Let us know if the issue continues.
"--verb n
Set output verbosity to n (default=1). Each level shows all info from the previous levels. Level 3 is recommended if you want a good summary of what's happening without being swamped by output.
0 -- No output except fatal errors.
1 to 4 -- Normal usage range.
5 -- Output R and W characters to the console for each packet read and write, uppercase is used for TCP/UDP packets and lowercase is used for TUN/TAP packets.
6 to 11 -- Debug info range (see errlevel.h for additional information on debug levels)." From openvpn.net for accruate information.- JimS-CLTNov 21, 2025Aspirant
I signed up for their stupid software support program at $100. Their next reply was "unless you sign up for our vpn cloud system, vpn only works with MacOS and Microsoft PCs." I definitely feel used.
- FURRYe38Nov 20, 2025Guru - Experienced User
This a FW version? should upgrade to V10.5.20.7...
