JimS-CLT
Nov 17, 2025Aspirant
Can't get my ios device to connect to Orbi 770 VPN.
I used the mobile device ovpn file vanilla except I changed the "verb" option to 3.... Here's my log file: [Nov 17, 2025, 13:45:32] Connecting to************ via UDP [Nov 17, 2025, 13:45:32] E...
JimS-CLT
Nov 19, 2025Aspirant
Tech support asked me to upgrade my router to a higher (apparently not published) rev level. I just now got home. I'll do it now. ChatGPT suggested making the verb option 3 to get more detailed error messages.
Nov 19, 2025Guru - Experienced User
This a FW version?
Let us know if the issue continues.
"--verb n
Set output verbosity to n (default=1). Each level shows all info from the previous levels. Level 3 is recommended if you want a good summary of what's happening without being swamped by output.
0 -- No output except fatal errors.
1 to 4 -- Normal usage range.
5 -- Output R and W characters to the console for each packet read and write, uppercase is used for TCP/UDP packets and lowercase is used for TUN/TAP packets.
6 to 11 -- Debug info range (see errlevel.h for additional information on debug levels)." From openvpn.net for accruate information.
- JimS-CLTNov 21, 2025Aspirant
I signed up for their stupid software support program at $100. Their next reply was "unless you sign up for our vpn cloud system, vpn only works with MacOS and Microsoft PCs." I definitely feel used.
