ThickD
Jun 29, 2025Aspirant
Change from Wired to Wireless Backhaul
Recently purchased an Orbi 770 (router + 2 satellites) Router on 1st floor, Satellites wired backhaul, one on 2nd floor, one on 3rd floor. Due to some issues I haven't quite figured out yet, the ...
Jun 30, 2025Guru - Experienced User
Try power cycling the RBS OFF for 30 seconds then back ON?
Does the RBS show as wired or wireless on the RBRs web page or Orbi app?
Does swapping RBS around, does the problem follow the RBS or remain at the remote location?
