GusTTavo
Oct 18, 2026Aspirant
Clients on Orbi Wi-Fi receive an IPv6 default gateway from an Orbi unit
I have a similar problem... My BGW320 is set to passthrough to my ORBI RBE770+2 satellites... Clients on Orbi Wi-Fi receive an IPv6 default gateway from an Orbi unit (fe80::ca10:2...
schumaku
Oct 19, 2026Guru - Experienced User
StephenB wrote:Passthrough normally means that the BGW320 is not routing. Which normally would require the Orbi to be set up as a router, not AP.
Nope: AP appears to be corrrect. The magic word in the GusTTavo post is: Firewalla
schumaku wrote:The magic word in the GusTTavo GusTTavo post is: Firewalla
I was thinking that, but wanted some confirmation (since the Firewalla can be set up as a bridge).
- schumakuOct 19, 2026Guru - Experienced User
Hm, and all IPv4 would come to the LAN from the ISP?
GusTTavo wrote:
IPv4 is correct on both paths.
- StephenBOct 19, 2026Guru - Experienced User
I just want clarity on the setup, with no need to guess.
