happygamer
Oct 18, 2026Aspirant
CM1200 to Orbi 370 no internet
Cables are all checked. When connecting CM1200 directly to PC (all ethernet cables), instantly internet access Setting up the Orbi 370 from CM1200, has wifi but no internet. Have done all the re...
Oct 18, 2026Guru - Experienced User
Power OFF both Modem and RBR for 1 minute then back on with the modem first then the RBR?
Be sure your using a good quality LAN cable between the Modem and RBR. CAT6 is recommended.
- happygamerOct 18, 2026Aspirant
I have done that sequence multiple times. Thr cable is only CAT5E. Does it have to be a CAT6 for Orbi 370 to work?
